kill on a 05 malibu
gcorrea
Silver - Posts: 436
Posted: September 10, 2005 at 2:51 PM / IP Logged
the normal set up is not working any ideas.middle of install.
gcorrea
mo12v
Posted: September 10, 2005 at 3:25 PM / IP Logged
Starter Circuit Is A Resistance Value Seen Between The WHITE And WHITE\BLACK Wires With The Key Held In The Start Position (Factory Anti-Grind Prevents Over Cranking During Testing.
Not sure why you would want Starter Kill, but U could probably split one of the above wires
MO
gcorrea
Silver - Posts: 436
Posted: September 10, 2005 at 4:49 PM / IP Logged
thanks sice it has the passkey i just thought i wouldnt use a kill. thanks for the reply
gcorrea
