Compustar Autostart in 88 Corolla GTS
Bakedgoat
Member - Posts: 6
Posted: September 17, 2005 at 10:17 PM / IP Logged
I cant seem to get my autostart going. I'm not sure where my tachometer wire goes into the brain, and I'm also not sure what to do with the status and light outputs (-) on my CN2 connector. Another thing is, there is a second relay on my CN1, with a long blue wire, and shorter purple wire. I know they're for 2nd ign, start, acc, but since I dont "think" I have one, so is it okay just to leave it unconnected? Thanks.
redpeppers
Silver - Posts: 483
Posted: September 18, 2005 at 12:05 AM / IP Logged
do u have the wire diagram for the remote start?
Where theres is a wire there's a way.
redpeppers
Silver - Posts: 483
Posted: September 18, 2005 at 12:08 AM / IP Logged
u shouldn't have to use the status out...and the negitive parking lights go to a light/green or light/green,blk at wires coming from steering column.  And that car does have a 2nd ign. it is postive trigger (BLACK/ orange) at ign. harness
Bakedgoat
Member - Posts: 6
Posted: September 18, 2005 at 1:59 AM / IP Logged
Hey, thanks for the reply. There is no diagram for the remote start. Compustar for some reason only state what comes out of the brain. But say a yellow wire coming out of the brain goes to a relay, then it just creates confusion. Actually, I have my green Ignition wire from the brain connected to the positive black orange coming out of the ignition harness. So I'll tape up the status out wire, and try to hook up some of my stuff. Do you happen to know where the tach wire coming from the GTS is? I think I have it connected to the wrong wire.
redpeppers
Silver - Posts: 483
Posted: September 18, 2005 at 2:02 AM / IP Logged
tach sould be black at igniter or fusebox.....i would go to igniter and test with multimeter.
Bakedgoat
Member - Posts: 6
Posted: September 18, 2005 at 3:52 AM / IP Logged
Okay, I'll go look for it tomorrow and I will get back to you. Thanks.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
