Posted: September 18, 2005 at 8:25 AM / IP Logged
Posted: September 18, 2005 at 10:15 AM / IP Logged
Posted: September 18, 2005 at 11:36 AM / IP Logged
Posted: September 18, 2005 at 1:17 PM / IP Logged
Posted: September 18, 2005 at 4:22 PM / IP Logged
Posted: September 18, 2005 at 6:11 PM / IP Logged
Posted: September 19, 2005 at 9:13 AM / IP Logged
Posted: September 19, 2005 at 3:56 PM / IP Logged
Posted: September 20, 2005 at 12:05 AM / IP Logged
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
There is the picture of my car right now. :) after I cut and soldered the wires into the remote start kit, then had to make it back to normal inorder to drive to work.I think i got the rest of the install mapped out. The 555P, interface only has 1 wire which goes back to the 791xv, which is the status wire. Seems a bit basic and "hackable" if all it needs it that. Now the other thing, it says to "Tap" into the 3rd and 4th pin of the PATS system, do i need an diode in those or can I litteraly, just tap into it, with a wire 3 way snap on?I haven't gotten anywhere with my driver side dorm problem, I guess I will just re-run the wire?Has anyone with a ford had problems with the alarm going off running from a simple 4 door - pin tap and diodes? I have seen and heard some use the diodes and a relay for triggering, but I havn't had any problems with it yet, and want to avoide them in the future. :)
