1997 mountaineer and 97 protege
projectprotege
Copper - Posts: 112
Posted: September 22, 2005 at 12:56 AM / IP Logged
i installed the ungo SR6000 on both of these vehicles and for some odd reason the remote start will not even try to activate on the lcd remote it says "inhibit" and the parking lamps indicator on both remotes for both vehicles flash on them.....
what does this mean?
is a relay needed for these installs?it does not say in the installation manual....any help would be greatly appreciated, thanks guys....
genehewett
Copper - Posts: 151
Posted: September 24, 2005 at 12:43 AM / IP Logged
This means there is a shutdown input that is active. The shutdown inputs are (gray) hood trigger, (small guage brown) brake, (small guage BLACK/ white) park/neutral.
The colors with "small guage" in front have matching colors only bigger. Check first!
The BLACK/ white must see ground to activate RS.
If gray is grounded it wont activate RS.
If brown gets 12v it will not activate RS.
