05' nissan 350z
mxxmikexx
Silver - Posts: 796
Posted: September 23, 2005 at 5:11 PM / IP Logged
anyone have any experience using the bypasskit NISSDL for the doorlocks on this vehicle? please post if you have used this part for the doorlocks, and if so, did it go smoothly any problems?
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
genehewett
Copper - Posts: 151
Posted: September 23, 2005 at 10:29 PM / IP Logged
This ia all info i got on it. Have not done one yet but what are you doing to vehic.?
Remote-Start, Security, Accessory, and  Audio
KPierson
Platinum - Posts: 3,527
Posted: September 23, 2005 at 10:39 PM / IP Logged
I've never heard of that module, but, it would definately be worth a shot.  The BCM (drivers kick) has a data bus wire from the door that I would assume would be the tie in point.  Otherwise, as I'm sure you know, you will be trying to run two wires through the molex plugs in to the door, not fun at all.  If the customer complains about the price just justify it by telling them that the BCM sits right under the molex plug that goes in to the door.  Once you put wires through that plug it will no longer be waterproof and there IS a chance that water will drip on the BCM (and its cheap plastic housing) and will eventually cause it to fail.
Kevin Pierson
mxxmikexx
Silver - Posts: 796
Posted: September 24, 2005 at 11:57 AM / IP Logged
yeah, ive done the g35, so i already know the fun about running wires through that damn plug !
Mike Battaglia
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
