88 honda accord door pin wiring
jw79
Posted: October 03, 2005 at 8:26 PM / IP Logged
Were can i find the door pin wiring for an 88 accord LXI 4 door "US Edition"? I have looked in all spots listed for models and years close to this but none matched. I have tryed looking for this BLACK/ white wire but have found only 2 in the car one is for ignition and the other doesnt test correctly (Eg: doesnt lose ground when doors are open or shut and doesn't produce voltage in either situation). This is very annoying as this has turned an hour project into a 3 day project (so far).
Thanks in advance,
JW79
jw79
Posted: October 03, 2005 at 9:06 PM / IP Logged
If thats the same one in the clump of wires along the door sill its the other wire I found already it doesnt show anything on the volt meter as a connection to ground or voltage source or termination.
jw79
Posted: October 04, 2005 at 7:27 AM / IP Logged
How high up are we talking? Up in the dash some where?, because I'm not seeing it
jw79
Posted: October 04, 2005 at 10:57 AM / IP Logged
the color for the drivers door is blue/green... the dome light does work fine. I tapped into that BLACK/ white wire at the back of the dash it reads ground when doors are open but 12 volts when there not? Why is this, I dont know but it does work for a door trigger should i put a diode on it or try something else?
jw79
Posted: October 05, 2005 at 6:40 AM / IP Logged
thanks for the help
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
