530T/529T exchange resistance
nava94
Silver - Posts: 296
Posted: October 05, 2005 at 10:17 PM / IP Logged
Hey guyz has anyone exchange the resistor on a 530T or 529T internally? Which resistor is it on the board? I have a vehicle with four windows up on a 95/97 suburban, an two windows do not fully roll up, because the windows get stuck a little and this causes the modules to stop.thanks in advance.
redpeppers
Silver - Posts: 483
Posted: October 05, 2005 at 10:20 PM / IP Logged
did u adjust the dip switchs?
Where theres is a wire there's a way.
nava94
Silver - Posts: 296
Posted: October 05, 2005 at 10:29 PM / IP Logged
530T yes I did but it still stops half way.
redpeppers
Silver - Posts: 483
Posted: October 05, 2005 at 10:33 PM / IP Logged
really even on high?  did u try putting it on the factory setting?  But to answer ur first question.....no i have never swaped the resistors out.
nava94
Silver - Posts: 296
Posted: October 05, 2005 at 10:38 PM / IP Logged
resistor settings on 530T changed from low/middle/high and no luck.
redpeppers
Silver - Posts: 483
Posted: October 05, 2005 at 10:52 PM / IP Logged
there is a factory setting too.....i think it use's the factory settings....if that doesnt work....beats me.....i have had the same problem of other cars....i just had to tell customer to forget it.
chrias
Member - Posts: 7
Posted: October 18, 2005 at 7:41 AM / IP Logged
Here's a link to the 530T modification. It worked on mine.
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1900.pdf
nava94
Silver - Posts: 296
Posted: October 20, 2005 at 10:03 PM / IP Logged
Chrias thanks, you made my day.I'll try this.thanks.
