Chevrolet Classic
aaronU
Copper - Posts: 73
Posted: October 19, 2005 at 9:50 PM / IP Logged
My friend got a 2005 Chevrolet Classic. What exactly is a chevrolet classic (Malibu?), and where can I find a wiring diagram for the vehicle?
Platinum - Posts: 12,488
Posted: October 19, 2005 at 10:08 PM / IP Logged
Basically looks like a Malibu, http://www.ecu.com/cars/P2411.html
aaronU
Copper - Posts: 73
Posted: October 19, 2005 at 10:13 PM / IP Logged
Does anyone have a wiring diagram for the car, or is it the same as a Malibu?
kgerry
Platinum - Posts: 3,455
Posted: October 20, 2005 at 4:51 PM / IP Logged
its a Malibu... not to be mistaken for a Malibu Maxx
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
aaronU
Copper - Posts: 73
Posted: October 20, 2005 at 6:07 PM / IP Logged
After looking around, it seems that this car is the old style Malibu that GM has keept as a fleet vehicle. It is a 2005 but it is not found on the regular Chevrolet website. It is on their fleet vehicle website. Would this vehicle have the same wiring as a new Malibu or an older one?
Chris Luongo
Platinum - Posts: 3,746
Posted: October 21, 2005 at 3:51 PM / IP Logged
aaronU, you have it correct.
The basically kept the old Malibu around to use as a rental car.
I believe the wiring on the Malibu was the same right from its introduction in 1997 up to 2003-----they re-used it as the Classic to save money----I don't see any reason they would make it different.
I'm not sure what you're installing, but when you pull out the radio to get your ignition wires, the best/easiest place to get parking lights is brown, positive trigger, at the back of the radio.
aaronU
Copper - Posts: 73
Posted: October 24, 2005 at 2:49 PM / IP Logged
Ok thanks for the info. I'm going to install a remote start. I'll look on the 1997-2003 diagram and pull the radio for the ignition wires.
A question that is off topic (and does not matter for the install), but how does the steering wheel lock work. When the key is on the column, it is mechanical. Is it electrical now that the key in on the dash? Just curious.
aaronU
Copper - Posts: 73
Posted: October 24, 2005 at 2:53 PM / IP Logged
I would imagine that I would need to use the starter wire like on the older models as opposed to not using the starter wire like on the new vehicles.
Any thoughts?
