01 excursion door key pad
78musicman
Copper - Posts: 78
Posted: October 20, 2005 at 7:32 PM / IP Logged
So i have a coworker that bought this vehicle and does not have the ddoor pad code for entering without the key.The dealer said he could get the # off the stock module to reset it,but they did not know within the truck it is located.If anyone knows how to reset or go about this thanks.
colorado tap the rockies
mo12v
Posted: October 20, 2005 at 7:36 PM / IP Logged
RKE ModuleLOCATED BEHIND THE DRIVER DASH TO THE LEFT OF STEER. COL.
MO
78musicman
Copper - Posts: 78
Posted: October 20, 2005 at 7:43 PM / IP Logged
So does that mean it is very hard to get to BEHIND THE DRIVERS DASHRATHER THAN UNDER THE DASH.If anyone knows?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 21, 2005 at 2:59 AM / IP Logged
Look up behind the e-brake (parking brake to some) youll see a white box on the firewall with a gray plug on the bottom....RKE module
