02 envoy key sense wire?
downlowez
Member - Posts: 6
Posted: November 06, 2005 at 7:45 PM / IP Logged
hey. im tring to find the wire for the passlock . ive seen it say lt green but i cut every one that was lt green and it still starts with the key. when i try to remote start it i can here the fuel pump kick in and the relays clicking but the starter does not crank. any help would be great!!
Downlowez,,
05gt
Silver - Posts: 628
Posted: November 06, 2005 at 10:16 PM / IP Logged
that is the right wire, it will be running down the steering column usually in the same wire loom as the ignition harness
gus1
Gold - Posts: 1,013
Posted: November 06, 2005 at 10:23 PM / IP Logged
The keysense wire is a light green..... you shouldn't have to cut it for a starter interface.
The passlock resistance wire is yellow, and is possibly the one that you are hunting for (there may be a couple yellows in there..... start it with the key, and then cut the thinnest yellow. If it is the right one, the passlock light should pop on)
Gus
05gt
Silver - Posts: 628
Posted: November 06, 2005 at 10:25 PM / IP Logged
if you take the steering shroud off up by the steering wheel, look at the top of the key cylinder or around that area, there should be a yellow wire, and ORANGE / black wire and a black I believe, the yellow wire is the one you cut
downlowez
Member - Posts: 6
Posted: November 07, 2005 at 5:04 PM / IP Logged
thanks guys, i was hunting the passlock wire witch i now know to be yellow and not lt green. i have found it and thank you guys for your fast responce!!
Downlowez,,
downlowez
Member - Posts: 6
Posted: November 07, 2005 at 5:06 PM / IP Logged
what is the difference between the keysense and the passlock? i thought it to be only one or the other.
Downlowez,,
kgerry
Platinum - Posts: 3,455
Posted: November 07, 2005 at 5:19 PM / IP Logged
passlock is your passive anti-theft circuit and the keysense circuit simply recognizes when the key has been slid into the ign cylinder....
one really has nothing to do with the other....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
