Blazer Light Flash Wiring
alex_8803
Member - Posts: 11
Posted: November 10, 2005 at 11:49 AM / IP Logged
Hey all, i tried wiring my lights to flash w/ lock and unlock on the way it said on my manual for the rem start, but then when i started the car, all my turn signal lights and come on and stay on so thaty there lit up orange... when i turn my car off and click the button they light up like they are supposed to... Any ideas to try and make the turn signal lights go off when the car is on until i use the turn signal...? ps. i have either - or + alarm output to activate lights... also i tried using the light flash diagram on the12volt.com diagram page also. and im using the brown wire at the light blue plug at the BCM. its a 1998.
redpeppers
Silver - Posts: 483
Posted: November 10, 2005 at 12:06 PM / IP Logged
those r daytime running lights.......u cant turn them off unless the car has programming to be able to turn them off.
Where theres is a wire there's a way.
