99-00 caravan Door locks
Alpine Guy
Platinum - Posts: 2,478
Posted: November 14, 2005 at 10:26 PM / IP Logged
I have a cust with a 99-2000 caravan and last time i looked at it i couldn't find the proper resistor to get the veh to unlock, i got it to lock, but it just wouldn't unlock.  Its been a few months since i looked at it last since we both forgot about it.
What is the resistance i need to send to the caravan, and what colour is the wire i need to send it too?
desh187
Copper - Posts: 310
Posted: November 14, 2005 at 10:50 PM / IP Logged
ground thru 1.5k ohm resistor to lock and ground thru 249 ohm resistor to unlock.
door lock wire color-WHITE/ dk green under junction block(single wire)
Alpine Guy
Posted: November 14, 2005 at 11:17 PM / IP Logged
what is the junction box? bcm? Any idea where abouts its located?  Thanks for your help so far.
05gt
Silver - Posts: 628
Posted: November 14, 2005 at 11:51 PM / IP Logged
the WHITE/ green wire is in a plug on the fuseblock
just take off the panels so you can get access to what is behind the dash on the drivers side, or try and look under the dash by the foot pedals, it will be there
Alpine Guy
Posted: November 15, 2005 at 9:29 AM / IP Logged
mxxmikexx
Silver - Posts: 796
Posted: November 15, 2005 at 3:27 PM / IP Logged
you can also just use a straight negative pulse directly at the factory lock/unlock relays under the dash and not even bother with additional relays and resistors.....
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Sunday, November 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
