2002 chevy tahoe door locks
boost555
Posted: November 14, 2005 at 10:56 PM / IP Logged
How do I make the unlock door locks to work on my aftermarket alarm? I need some info thanks
05gt
Silver - Posts: 628
Posted: November 14, 2005 at 11:52 PM / IP Logged
unless the alarm does positive pulse door locks you will need relays to do this
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2005 at 1:51 AM / IP Logged
2002 chevy tahoe door locks -- posted image.Wire your relays like so
Chris Luongo
Platinum - Posts: 3,746
Posted: November 15, 2005 at 7:50 AM / IP Logged
Three (or is it four) plugs at the BCM, under the steering column. You will see quite a few white and blue wires there, though.
In the plug all the way to the left, the locks are in the bottom row----they are the only blue and white that are right next to each other. Supplying a positive trigger to either wire will lock or unlock the doors.
The same wires are also in one of the plugs in the driver's fusebox, if that is easier for you.
Platinum - Posts: 12,488
Posted: November 15, 2005 at 8:20 AM / IP Logged
Here's a little help for the wires. Use the diagram above to reverse polarity on the (-) trigger output of the alarm system.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
