2006 Mitsubishi Eclipse GT Wiring
ibkaraoke
Posted: November 16, 2005 at 8:00 PM / IP Logged
I am getting a Visionguard 6000 remote start and alarm system that actually takes pictures of the intruder and then transmits it to the pager. My problem is my car is so new I don't have any wiring info on it. Does anyone know where I can get some info on the wiring like the colors or the wire, location, etc. I hope to install thid next week!
Rich
cntrylvr79
Silver - Posts: 582
Posted: November 16, 2005 at 8:13 PM / IP Logged
12voltsblue / YELLOW (40A) + ignition harness
StarterBLACK / YELLOW + ignition harness
Second StarterN/A
Ignitionred + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessoryblue/red + ignition harness
Second Accessoryblue/black + ignition harness
Keysenseblue/red  ign harn or ETACS ECU, pin 30
Notes: This wire rests at ground, and goes to an open circuit when the key is inserted into the ignition cylinder.
The ETACS (Electronic Time and Alarm Control System) ECU is attached to the back of the fuse box. The plugs are on the right side edge.
Power Lockpurple to PURPLE / white - driver kick or ETACS ECU, pin 33
Notes: The ETACS (Electronic Time and Alarm Control System) ECU is attached to the back of the fuse box. The plugs are on the right side edge.
Power Unlocklt. GREEN/ red - driver kick or ETACS ECU, pin 34
Lock Motorblue/red 5wi28 pin plug above fuses, pin 19
Unlock Motorblue/black 5widriver kick or ETACS ECU, pin 22
Parking Lights+GREEN / WHITE + 15 pin plug below fuses, pin 2
Parking Lights-N/A
HazardsGREEN/ YELLOW - switch or ETACS ECU, pin 55
Turn Signal(L)GREEN/ red + 15 pin plug below fuses, pin 8
Turn Signal(R)GREEN/ YELLOW + 15 pin plug below fuses, pin 13
Reverse LightRED / blue + driver kick, harness to rear
Door Triggerlt. green (D), yellow (P) - see notes
Notes: The driver door trigger is lt. green in a 15 pin plug below the fuses, pin 6. The passenger door is yellow at the ETACS ECU, pin 65. Use both wires and diode isolate each.
Dome SupervisionGREEN/ orange - 3 pin plug below fuses, pin 1
Trunk/Hatch PinRED / yellow - driver kick or ETACS ECU, pin 62
Hood PinN/A
Trunk/Hatch Releasewhite 5widriver kick or ETACS ECU, pin 32
Power Sliding DoorN/A
Factory Alarm Armlt. GREEN/ black - driver kick or ETACS ECU, pin 42
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors.
Factory Alarm DisarmRED / green - driver kick or ETACS ECU, pin 25
Notes: Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors with a double pulse.
Disarm No Unlock
TachometerNOT red ac any fuel injector
Notes: On the 2.4L, can also go to any ignition coil and use the wire that is NOT BLACK/ orange or black.
On the 3.8L, can also go to any ignition coil and use the wire that is NOT BLACK / YELLOW, BLACK/ red or black.
Wait to startN/A
Brake Wiregreen + brake pedal switch
Parking BrakeYELLOW /GREEN - parking brake switch
Horn Triggerlt. green - switch or ETACS ECU, pin 44
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2006 Mitsubishi Eclipse GT Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Cause I'm So white and nerdy...
First Class Certi-fried installer
