honda accord 1997 SE parking light
minhbach
Copper - Posts: 93
Posted: November 19, 2005 at 1:53 AM / IP Logged
Could any body help me with the problem on the parking light whenever you press the button on the alarm. The parking light should be on/off. It is not the alarm system nor the 10 fuse off the white wire from the alarm system asianwolf 8000rs. There was a remote starter commando ez-2100. It was working fine with the parking lights but it started on this remote starter already and same as this 8000rs alarm system. Even the factory keyless entry won't flash when you press the button. The parking light is RED / white(+) for this vehicle. The parking light only on when you turn on switch at the steering wheel not when you arm/disarm the system. Fuse under DKP is checked and it 's good. Would that be the parking light relay??? Any help would be appriciated.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 19, 2005 at 1:57 AM / IP Logged
The parking light is NOT RED / white for this vehicle.....it's RED / black, like most ALL honda's (old ones anyhow). Its in the drivers kick......
tmsflasher
Member - Posts: 6
Posted: November 19, 2005 at 3:12 AM / IP Logged
How's the asianwolf 8000RS, do you like it? Is the screen display actually the way they have it portrayed on the website? Is it reliable? One of the reasons I don't like to install these alarms is because it doesn't seem tough and reliable, that's why I chose Autopage 855 for my car.
minhbach
Copper - Posts: 93
Posted: November 19, 2005 at 4:17 PM / IP Logged
Sorry it is a RED / BLACK. Can you tell me what wrong with the above problem post KarTuneMan. Thank you
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
