Rain or water sensor?
wester97
Member - Posts: 32
Posted: November 19, 2005 at 11:39 PM / IP Logged
Anyone know of a water sensor that I could use so that i dont end up leaving my windows cracked and have a freak storm soak my car again?
Obviously going to be used with a window module and timer ....
Thanks!!
dualsport
Silver - Posts: 983
Posted: November 20, 2005 at 1:19 PM / IP Logged
Sounds interesting-
There's probably a commercial one out there, but something like this should work, if you can't find it and want to try making it yourself from a few cheap components-
Rain or water sensor? -- posted image.
Component List >>>
1uF cap
1N4001 diode
RELAY
BS170
10M, 1M, 330 ohm resistors
14011 CMOS NAND gate
Maybe use a pair of header pins for the contacts, which you would put in a shallow tray that would collect the rain water- the idea is that when the water touches both pins, it'll conduct and short the two together, triggering the circuit and briefly closing the relay.
It outputs a single pulse, and won't repeat until the contacts dry out and open the circuit again.
dualsport
Silver - Posts: 983
Posted: November 20, 2005 at 1:23 PM / IP Logged
By the way, if your trigger input doesn't really require any current drive, you could probably delete the BS170 and relay shown, to cut down on the parts count.
wester97
Member - Posts: 32
Posted: November 20, 2005 at 5:07 PM / IP Logged
Wow.  Really makes me wish I was an EE!
dualsport
Silver - Posts: 983
Posted: November 20, 2005 at 9:17 PM / IP Logged
Sure enough, a google search shows something tailor made for the purpose: rainmain
Ween
Platinum - Posts: 1,368
Posted: November 20, 2005 at 9:50 PM / IP Logged
hi,
if i recall correctly, Micro-sciences/Twindows had an add on piece to their sunroof
controller modules that performed a rain sense(auto-close) and temperature sense(auto-vent).
the rain sensor portion was a circuit board (gold plated  for corrosion protection) that was installed
near the windshield.  also i'm pretty sure i could trigger the auto-close input of their window modules
using the above circuit board directly connected to that particular input.
more input for you.
mark
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
