2000 yukon, remote start
tintman97
Copper - Posts: 113
Posted: November 25, 2005 at 7:10 PM / IP Logged
Installed a mars 22 RS all wires are correct.   Used a Omega gm databus bypass and it programed but every time i start the truck by RS it shuts down in 3 sec.  Security right  well even with the key in the ignition it still shuts down after 3 sec.  i tryed 2 bypasses and 2 RS units.  Im stumped anyone got any ideas
Snapper
murraymurray
Member - Posts: 25
Posted: November 25, 2005 at 8:14 PM / IP Logged
Check your tack setting and set it accordingly depwends where you got the signal from
murraywatchel
tintman97
Copper - Posts: 113
Posted: November 25, 2005 at 9:48 PM / IP Logged
it was tachless  voltage monitoring    i used.   i cant belive it makes that big of dif.  the truck  starts then dies 3 sec afterwards.  Even with the key in the cylnder.
snapper
russ lund
Copper - Posts: 188
Posted: November 26, 2005 at 4:00 PM / IP Logged
That is passlock II the key in the cylinder has no effect,only when the key is turned to the start position.Use a tach wire its way more reliable.
BigDog
tintman97
Copper - Posts: 113
Posted: November 26, 2005 at 6:42 PM / IP Logged
so does the key matter thar i programed from as  the key i used was not orignal.
Snapper
murraymurray
Member - Posts: 25
Posted: November 26, 2005 at 7:01 PM / IP Logged
The key in the ignition in the run position but engine not running, Try and remote start it and it will more than likely start and  stay running. Or else try  start the car with the key and then hit start on the remote and then remove the keys and if engine stays running it is Passlock problem. Passlock ll does not have a chip in the key if the key turns in the tumbler it will work.
Thankyou
Murray
murraywatchel
mo12v
Posted: November 26, 2005 at 7:05 PM / IP Logged
What do you have the BLACK / Yellow wire hooked to from MARS 22??
Did you set the switch to Smart Start?
Did you adjust the Smart Adjustment to Blink while running?
Also be sure the TACH Adjustment is turned all the way down if using Smart Start
MO
tintman97
Copper - Posts: 113
Posted: November 26, 2005 at 7:45 PM / IP Logged
black and yellow on constant wire i was short of time.   ill hook it to white on the coil but i think its a bypass issue not  a tach prob myself.  Omegas smart tach is pretty reliable.   i had it on smart tach i tryed 2 units also .  I fell retarded cause the bypasses are so easy to program.
Snapper
mo12v
Posted: November 26, 2005 at 8:20 PM / IP Logged
10 - 4............It does sound like a ByPass issue
Voltage Sense is reliable on most vehicles, but Tahoe, Yukon & Trailblazer have been a few of the GM Vehicles that I have found the TACH needs to be hook - up
MO
tintman97
Copper - Posts: 113
Posted: November 26, 2005 at 8:37 PM / IP Logged
k so that will work though turning the key to the on position and hiting the RS?  dosent quite match what was said in the first place.
Russland siad
"That is passlock II the key in the cylinder has no effect,only when the key is turned to the start position"
Snapper
thanks for the help
