2002 Elantra GT Keyless entry...I think?
ih8tktz
Member - Posts: 22
Posted: December 16, 2002 at 12:32 PM / IP Logged
My vehicle likes to lock its door on its own for some reason, I would like to find a wiring diagram for my ECU to dissable the factory alarm and keyless entry as I have an Alpine security system in the car now, but its only for shock and motion, I would like to have keyless entry and lights on the Alpine system but I need a diagram to do so, any help would be appreciated.
D Simpson
Platinum - Posts: 12,488
Posted: December 16, 2002 at 12:42 PM / IP Logged
What is the model number of the Alpine unit ? Here is the wiring information for the 2002 Elantra:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+  |ignition harness            |
|          STARTER|white               |+  |ignition harness            |
|         IGNITION|red                 |+  |ignition harness            |
|        ACCESSORY|red                 |+  |ignition harness            |
| SECOND ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|blk/org or blue *1  |F  |white 22 pin plug in DKP    |
|     POWER UNLOCK|same wire           |   |                            |
| PARKING LIGHTS +|grn/org(L), pink (R)|   |black 14 pin plug *2        |
| PARKING LIGHTS -|blue                |   |steering column             |
|       HEADLIGHTS|white               |-  |steering column             |
|     DOOR TRIGGER|yellow              |-  |white 22 pin plug in DKP    |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |white 22 pin plug in DKP    |
|         HOOD PIN|GREEN/ black         |-  |yellow 18 pin plug *3       |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|blue                |   |ECM *4                      |
|      SPEED SENSE|gray/orange         |   |data link connector *5      |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|red                 |-  |steering column             |
|           WIPERS|green (L), pink (H) |-  |steering column             |
|  LF WINDOW UP/DN|brown - orange      |A  |drivers window switch       |
|  RF WINDOW UP/DN|green - gray        |A  |drivers kick panel          |
|  LR WINDOW UP/DN|pink - blue         |A  |drivers kick panel          |
|  RR WINDOW UP/DN|white - brown       |A  |drivers kick panel          |
| SUN RF OPN/CLOSE|yellow - yel/red    |A  |sun roof motor              |
|        RADIO 12V|red                 |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|pink                |+  |radio                       |
|    POWER ANTENNA|gray/orange         |+  |radio                       |
|       LF SPEAKER|white - brown       |   |radio                       |
|       RF SPEAKER|green - orange      |   |radio                       |
|       LR SPEAKER|yellow - black      |   |radio                       |
|       RR SPEAKER|orange - blue       |   |radio                       |
Notes:NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. *1 These wires are only in vehicles with keyless entry. The blk/org wire will test when when moving the driver lock knob, the blue wire will test when moving the passenger lock knob. Vehicles without keyless entry need to add an actuator in the driver door. *2 The plug is on the front of the fuse box below the fuses. *3 The plug is behind the fuse box. *4 The ECM is above the driver kick panel, the tach wire is in pin 66. Can also find tach at the ignition coils on the driver side of the engine, use either the yellow or green wire. *5 The data link connector is under the driver side dash under the steering column.
ih8tktz
Member - Posts: 22
Posted: December 17, 2002 at 7:42 AM / IP Logged
The nuber to my Alpine alarm in SEC-150R, its the one with impact and 2 stage radar
With ref to the immobilizer system, my vehicle is equipped with one I had a look at the Hyundai electronic manual last night while at the dealership, it appears to have all kinds of parts to the keyless entry, there is the SMATRA, ETACS ( i think thats part), a burglar relay by the steering column.
I have also been told that bypassing the factory alarm will fry my comp, is this true?  The dealership told me this, I honestly think its a crock because they also told me that I couldn't remove the factory stereo but that was a lie, unfortunately my alternator isnt quite strong enough to power the system properly.
Thanks again
Donnie
Posted: December 17, 2002 at 1:04 PM / IP Logged
responded to this on your other post.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
