89 F150 Accessory wire
forbidden
Platinum - Posts: 5,354
Posted: December 06, 2005 at 5:57 PM / IP Logged
Is missing in action. None of the wires from any of the wiring guides actually matched the wires we found in this vehicle.  The RS works fine but no heater. Wondering if anyone has come across this before?
Mike M2
Platinum - Posts: 2,652
Posted: December 06, 2005 at 6:03 PM / IP Logged
Should be gray / YELLOW. When in doubt, energize them all with relays...
Mike M2
Tech Manager
CS Dealer Services
forbidden
Posted: December 06, 2005 at 6:54 PM / IP Logged
Nope, go fish! After looking a little closer and discovering that the main bolts that hold the steering column to the dash were missing and then looking closer at the wiring, it looks like everytning has been modified from stock. It actually appears that the heater circuit is now controlled by a relay that is a neg trigger. WTF?
infinkc
Copper - Posts: 438
Posted: December 06, 2005 at 7:13 PM / IP Logged
are you able to test for it? off the ignition switch? or just test it at the heater to see what goes 12v when the car is turned on and run power to that point.
There are 10 types of people in the world, ones that understand binary and ones that dont.
