2001 VW Jetta, Door Lock/Window
carstereoman
Member - Posts: 48
Posted: December 07, 2005 at 1:37 PM / IP Logged
Hey guys,
I'm having a problem and hopefully one of you has an answer. I'm working on a 2001 VW Jetta GLS, the customer asked me while I was working on it if I could take a look at her passenger side door lock and window switches. The entire module isn't getting any power I assume because the lights are not illuminated any more as they should be. Of course the lock/unlock and window switches aren't doing anything; no noise, nothing at all. I checked all the fuses, no avail on that matter. I'm not sure what else could be causing the problem. Any help would be great, thanks.
gus1
Gold - Posts: 1,013
Posted: December 07, 2005 at 2:25 PM / IP Logged
Check the grounds for the door. There will be a factory grounding point located behind the kickpanel on the passenger's side. Check it for corrosion/tightness. Next thing is to check continuity from this point to the door module (on window motor) grounds, the switch grounds, etc.. you may have a broken wire in the boot.
Does anything work from the driver's side switches?
Gus
redroc
Member - Posts: 11
Posted: December 08, 2005 at 8:52 PM / IP Logged
If it get into taking the car apart,try unplugging the main harness in the drivers door.I have done this on a few vw's and once you reconnect it everything works again.
cloneman315
Member - Posts: 24
Posted: December 08, 2005 at 9:20 PM / IP Logged
check all the wires under the drivers carpet they corrode all the time
