can I add starter to Compustar 2W900FM?
viptime
Member - Posts: 33
Posted: December 08, 2005 at 8:30 AM / IP Logged
Is there a way to add a remote start to Compustar 2W900FM-A ? and what would I need for it?
Please help
Thank you
Alex
dare_ds69
Silver - Posts: 419
Posted: December 09, 2005 at 9:29 AM / IP Logged
the compustar has a remote start build in  check the compustart.org
how own your mind, control your life.
MECP certified. always use a DMM
Platinum - Posts: 12,488
Posted: December 09, 2005 at 9:34 AM / IP Logged
Alex, the FM-A system uses a different CPU than the FM-S. The best thing to do is to replace the CPU with a CM3000 and you will have all the same harness as the FM-A but you will gain remote start options. If you don't want to go this route you can always pick up a 1WAM-S system and wire it in and using an AUX channel you can pulse the 1WAM-S to start by using the temp sensor input wire on the CM4200 CPU.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
