2002 Altima remote start install
tculbert
Member - Posts: 6
Posted: December 18, 2002 at 12:55 PM / IP Logged
Am currently getting ready to install a remote start to my 2002 Nissan Altima.  Starter model is an RS4LX made by Omega.  Does anyone know anything about this piece or exactly what it takes to install???  I have done many installations but have no experience with remote starters.
Please help!!!
Platinum - Posts: 12,488
Posted: December 18, 2002 at 1:07 PM / IP Logged
You will require a bypass module for the Nissan as well there are two starter wires that need to be powered up at time of remote start. Here is the wiring diagram for this car:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|green               |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|red                 |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness            |
|       POWER LOCK|pink *7             |-  |pin 37 @ BCM by fuse box    |
|     POWER UNLOCK|brown *7            |-  |pin 44 @ BCM by fuse box    |
|       LOCK MOTOR|yellow/red          |   |pin 30 @ BCM by fuse box    |
|     UNLOCK MOTOR|GREEN / WHITE         |   |pin 23 @ BCM by fuse box    |
|    DISARM DEFEAT|GREEN/ red           |   |pin 31 @ BCM by fuse box    |
| PARKING LIGHTS +|RED / blue            |   |driver kick panel           |
|       HEADLIGHTS|blu (L), RED / yel (R)|+  |IPDM E/R *1                 |
|     DOOR TRIGGER|*2                  |-  |BCM to right of fuse box    |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|PURPLE / white        |-  |pin 18 @ BCM by fuse box    |
|         HOOD PIN|yellow/black        |-  |hood pin switch             |
|TRNK/HTCH RELEASE|RED / blk or blu/red  |-  |pin 76 @ BCM by fuse box    |
|  FCTRY ALARM ARM|pink/blue *3        |-  |driver switch in door       |
|FCTRY ALRM DISARM|WHITE/ blue *3       |-  |driver switch in door       |
|       TACHOMETER|WHITE/ green         |   |ECM behind glove box *4     |
|      SPEED SENSE|blue / YELLOW *5      |8  |pin 9 @ instrument cluster  |
|       BRAKE WIRE|RED / green           |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |-  |steering column             |
|           WIPERS|blu (L), blu/blk (H)|-  |wiper motor                 |
|  LF WINDOW UP/DN|blu/red - blu/wht   |A  |driver window switch        |
|  RF WINDOW UP/DN|green - yellow *6   |A  |driver kick panel           |
|  LR WINDOW UP/DN|purple - blue       |A  |driver kick panel           |
|  RR WINDOW UP/DN|RED / yel - yel/blk   |A  |driver kick panel           |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|YELLOW /GREEN        |+  |radio                       |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|purple              |+  |radio                       |
| RADIO ILLUMINATE|RED / blue            |+  |radio                       |
|    POWER ANTENNA|green               |+  |radio                       |
|       LF SPEAKER|blu/wht - blu/red   |   |radio or amp under rear deck|
|       RF SPEAKER|wht/blk - blu/blk   |   |radio or amp under rear deck|
|       LR SPEAKER|grn/yel - blk/yel   |   |radio or amp under rear deck|
|       RR SPEAKER|blue - red          |   |radio or amp under rear deck|
Notes:NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 The IPDM E/R (Intelligent Power Distribution Module Engine Room) is under the hood behind the passenger side headlight. *2 The LF door trigger is lt. blue in pin 14, RF door is pink/blue in pin 10, and the LR and RR door is RED / black in pin 11. *3 Meter these wires while turning the key in the driver door key cylinder. These wires will also lock and unlock the doors. Unlock requires a double pulse. *4 On the 4 cylinder vehicles it is in pin 36, and on the 6 cylinder it is in pin 34. Can also go to one of the ignition coils and use the wire that is NOT red or black. *5 If vehicle has the midline audio system or BOSE, the vehicle speed sense is also found at the radio, it is pink. *6 If vehicle has auto up/down on the front passenger window switch then must go into the passenger door and use blue for up and GREEN/ black for down. *7 These wires are only available on vehicle with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
tculbert
Member - Posts: 6
Posted: December 19, 2002 at 8:16 AM / IP Logged
thanks for the info Jeff.
I'll give it a try.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
