Wiring for 2001 Audi A6
srusin1
Copper - Posts: 86
Posted: December 19, 2005 at 4:05 PM / IP Logged
Anyone have the diagram for a 2001 Audi A6?
thepencil
Gold - Posts: 1,526
Posted: December 19, 2005 at 5:02 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - AUDI / A6 / 2001 / Remote Start
12volts red    +   ignition harness
Starter RED / black    +   ignition harness
Second Starter blue    +   ignition harness
Ignition black    +   ignition harness
Second Ignition
Third Ignition
Accessory yellow/black    +   ignition harness
Second Accessory
Keysense
Power Lock GREEN/ blue    -   C3, pin 12, keyless modul
Notes: Unlock requires a double pulse. Ignition locks will cause the door lock switch and the interior lights not to work while driving, be sure to turn it off.
The keyless module is under the driver side floor mat in front of the seat.
Power Unlock brn/yel or brn/gry    -   C3, pin 6, keyless module
Notes: The keyless module is under the driver side floor mat in front of the seat.
Lock Motor
Unlock Motor
Parking Lights+        headlight switch
Notes: Vehicles with DRL use GREEN/ gray at the switch, and must use relay to isolate the switch side to prevent backfeed to the ignition. Vehicles without DRL use GREEN/ black and GREEN/ red at the switch.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      -   keyless module
Notes: Drivers door trigger is GREEN/ YELLOW in Conn. 5, pin 1, front passenger door is RED / gray in C5, pin 10, left rear door is BLACK/ red in C5, pin 12, and right rear door is BLACK/ purple in C5, pin 14.
Dome Supervision comes on with unlock
Trunk/Hatch Pin
Hood Pin gray/red    -   C3, pin 10, keyless modul
Trunk/Hatch Release PURPLE / green    +   release switch
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer        ignition coils
Notes: For tach use gray / YELLOW, GREEN / WHITE, or GREEN/ gray at the coil pack on the front of the motor.
Wait to start
Brake Wire RED / black    +   brake pedal switch
Parking Brake
Horn Trigger BLACK / YELLOW    +   horn relay, driver side dash
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555B
Alternate Part2 #: 555U
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: See DirectFax document 1056 for additional wiring information.
Be careful whose advice you buy, but be patient with those who supply it.Wiring for 2001 Audi A6 -- posted image.
