parking light 05 toyota sienna
Johnnynguyen20
Copper - Posts: 89
Posted: December 22, 2005 at 5:53 PM / IP Logged
does anyone have install a R/S for this car. i have a problem with with parking light for this vehicle. what's the parking wire color for this vehicle. i have used the (-) Nega parking lights from the Headlight switch, that's GREEN/ BLACK (-) but i didn't work. so pleaes help. i aprecite
Johnnynguyen
Mike M2
Platinum - Posts: 2,652
Posted: December 22, 2005 at 6:08 PM / IP Logged
That's the correct wire. There is more than one in that harness so you must test....
Mike M2
Tech Manager
CS Dealer Services
nava94
Silver - Posts: 296
Posted: December 22, 2005 at 6:11 PM / IP Logged
what kind of alarm/remstart?If dei you have to change polarity setting on the side of the brain. Double check the wire with a digital multimeter.
messiah9966
Member - Posts: 45
Posted: December 22, 2005 at 6:18 PM / IP Logged
you may need to use a relay on your parklight output as well
Mike M2
Posted: December 22, 2005 at 7:41 PM / IP Logged
No relay needed...
Mike M2
Tech Manager
CS Dealer Services
forbidden
Platinum - Posts: 5,354
Posted: December 22, 2005 at 8:14 PM / IP Logged
My pic even shows it at the molex in the steering column where the molex plugs into the stock area.
Johnnynguyen20
Copper - Posts: 89
it's a scytek 2 way remote start/alarm system
Johnnynguyen
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
