1993 Honda Civic, Alarm/starter
radeonboy
Member - Posts: 12
Posted: December 22, 2005 at 7:37 PM / IP Logged
Hello folks,
I am new to the site, first post. I consider myself at least knowledgeable on computers and have taken some courses on electronics and whatnot. I have a somewhat dim/light grasp on these kinda things. I am 18.
Anyway long story short, I am planning to install my first car alarm/starter on my 1993 Honda Civic DX hatchback. I just purchased an Autopage RS-720LCD unit from eBay (hopefully it comes).
I was just wondering how easy or hard is it to install an alarm/starter system in a vehicle? I just got the wiring schematics from this site (told me to go to Bulldog security) and so I now know at least which colors to look for.
I plan to also do a backup battery install for siren, and also a fuel pump cutoff switch. First thing I just need to do is just install first.
Does anyone have material or tips they would like to share with me regarding installations?
BTW: Is there a way to check if the alarm unit is working fine before I hook it up? I would hate to spend hours installing it and find out the unit is bad, especially when its on eBay.
Thanks.
Mike from Canada :)
05gt
Silver - Posts: 628
Posted: December 22, 2005 at 7:57 PM / IP Logged
the civic is the most straight forward install there is, shouldn't be a problem
forbidden
Platinum - Posts: 5,354
Posted: December 22, 2005 at 8:10 PM / IP Logged
If you are concerned about the alarm not working, you should not have been shopping on E-Bay in the first place. What you thought might be a good deal, can turn into a nightmare and huge $ in the blink of an eye. Any alarm is only as good as the install. If you have the proper tools to do the job, there are plenty of experienced people here on the site to step you through it.
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 11:01 AM / IP Logged
Yes but hopefully that is not the case for mine.   This seller has sold to over 30,000+ people and has a 98.9% rating. Hopefully my case will be within the 98.9%.
Without racing, there is no Honda
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 11:03 AM / IP Logged
bobk, what you would you suggest I kill, and why not the fuel pump? I've heard its one of the better things to do. Is there something else that is better?
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 11:08 AM / IP Logged
Also you know those starter kill relays that come with the alarms? Do those pulg in somewhere in the car, or am I just going to hook up wires to it and then put it away with the brain?
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 5:53 PM / IP Logged
So what would you recommend Bobk? Any better thing than to kill the fuel pump?
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 5:57 PM / IP Logged
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 23, 2005 at 10:01 PM / IP Logged
Does anyone know if the AutoPAge RS-720LCD can work for both manual and automatic transmissions?
- Soichiro honda
radeonboy
Member - Posts: 12
Posted: December 24, 2005 at 3:55 PM / IP Logged
Anyways I am going to get another siren (no battery backup) so where should I hook it up to?
I plan to have two non-battery backup siren and 1 battery backup siren.
Where should I hook up the non battery siren to and the other battery to?
THANKS
- Soichiro honda
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
