2005 gmc denali diagram & modules
tonywin
Posted: January 01, 2006 at 5:46 PM / IP Logged
hello,
does anyone have the correct diagram & bypass modules for a 2005 gmc denali.
thanks.
tony
Mike M2
Platinum - Posts: 2,652
Posted: January 01, 2006 at 5:54 PM / IP Logged
12volts red (40A), red (40A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601. Upper trim level vehicles may have a door lock switch on the right rear panel. If present use white (-) for lock and lt. blue (-) for unlock.
Power Unlock see power lock
Lock Motor gray  5wi driver door module in door
Unlock Motor tan  5wi driver door module in door
Parking Lights+ brown  +  driver kick panel
Parking Lights- gray/black  -  switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white  -  hazard switch
Turn Signal(L) dk. green  +  turn signal switch
Turn Signal(R) lt. green  +  turn signal switch
Reverse Light lt. green  +  BCM, black plug, pin F
Door Trigger see notes  -  see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black  +  BCM, black plug, pin E
Trunk/Hatch Pin pink/black  -  BCM, purple plug, pin A1
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black  -  switch or BCM, gray plug, pin B9
Memory Seat 1 red  +  driver door module in door
Memory Seat 2 pink  +  driver door module in door
Memory Seat 3 N/A  +
2005 gmc denali diagram & modules -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and RED / white (not used).
Door Lock Interface
Required:
Yes
Type:
Data Bus
Part #: 456G
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Mike M2
Tech Manager
CS Dealer Services
mobileworks
Copper - Posts: 136
Posted: January 01, 2006 at 7:33 PM / IP Logged
tonywin
Posted: January 20, 2006 at 8:58 PM / IP Logged
hello,
does anyone knows if .. the 05 yukon denali diagram are the same as the regular 05 yukon gmc?
sparkie
Platinum - Posts: 2,061
Posted: January 21, 2006 at 10:58 AM / IP Logged
Yes they are. The Denali is only a Yukon with more options.
sparky
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
