2003 buick lesabre
bry_gordan
Member - Posts: 34
Posted: January 01, 2006 at 6:06 PM / IP Logged
does anyone have a good wiring diagram for remote start on a 03 buick lesabre
Brian Gordan
Mharvey
Copper - Posts: 76
Posted: January 01, 2006 at 6:42 PM / IP Logged
REMOTE START
 Battery  RED(OR ORANGE OR ORANGE / BLACK)  (+)  IGNITION SWITCH HARNESS
 Ignition 1  PINK  (+)  IGNITION SWITCH HARNESS
 Ignition 2  WHITE  (+)  IGNITION SWITCH HARNESS
 Accessory 1  ORANGE  (+)  IGNITION SWITCH HARNESS
 Starter 1  YELLOW (OR PURPLE)  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  PASSKEY III
 Anti-Theft Descript  AN RF SIGNAL ACTIVATED SYSTEM
 Key Sense  LIGHT GREEN  (-)  IGNITION SWITCH HARNESS
 Neutral Safety  YELLOW  (-)  AT VEHICLE FUSE PANEL ON DRIVERS SIDE
 Tachometer  WHITE  (-)  AT IGNITION COIL, FRONT OF ENGINE
 Speed Sense  (DARK GREEN / WHITE)
 Parking Lights  BROWN / WHITE  (-)  AT VEHICLE LIGHT SWITCH
 Brake Lights  WHITE  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  LIGHT GREEN  (+)  IN HARNESS TO TRANSMISSION
 Horn  BLACK  (-)  AT THE DIM MODULE
SECURITY
 All Door Trigger  GRAY/BLACK AND GRAY  (-)  DRIVER KICKPANEL AND DRIVER CENTER PILLAR
 LF Latch  TAN
 RF Latch  DARK BLUE
 LR Latch  DARK BLUE
 RR Latch  DARK BLUE
 Trunk Trigger  ORANGE / BLACK  (-)  AT LIGHT IN TRUNK
 Alarm Disarm  LIGHT GREEN  (-)  MODUAL IN DRIVER DOOR
 Alarm Arm  TAN  (-)  MODUAL IN DRIVER DOOR
Headlights-Lo  YELLOW  (+)  AT VEHICLE LIGHT SWITCH
 LF Pk Lt Bulb  BROWN  (+)  AT FRONT LEFT PARKING LIGHT
 RF Pk Lt Bulb  BROWN  (+)  AT FRONT RIGHT PARKING LIGHT
 LR Pk Lt Bulb  BROWN  (+)  AT REAR LEFT PARKING LIGHT
 RR Pk Lt Bulb  BROWN  (+)  AT REAR RIGHT PARKING LIGHT
 Wipers-Lo  VIOLET (OR WHITE)  (+)  IGNITION SWITCH HARNESS
 Trnk Release  BLACK ( OR LIGHT BLUE )  (-)  IN INSIDE DRIVERS DOOR AT POWER WINDOW SWITCH
Power Unlock  ORANGE / BLACK  (-)  IN DRIVERS DOOR
 PowerLock  RED / BLACK  (-)  IN DRIVERS DOOR
 Driver Mtr Unlock  TAN  (+)  IN DRIVERS DOOR AT SWITCH
 Driver Mtr Lock  GRAY  (+)  IN DRIVERS DOOR AT SWITCH
 Pas Mtr Unlock  TAN  (+)  IN DRIVERS DOOR AT SWITCH
 LF Window Up  (DARK BLUE)
 LF Window Dn  (BROWN)
 RF Window Up  (DARK BLUE)
 RF Window Dn  (BROWN)
 LR Window Up  (DARK BLUE )
 LR Window Dn  (BROWN)
 RR Window Up  (DARK BLUE )
 RR Window Dn  (BROWN)
 Sunroof Close  (RED)  (-)  AT THE SUNROOF MOTOR
Module 1  DIM - IN FRONT OF THE BLOWER MOTOR NEAR THE PASSENGER KICK
 Module 2  RIM - BEHIND REAR SEAT UPPER CORNER DRIVERS SIDE
 Module 3  CRUISE MODUL - IS LOCATED UNDER THE HOOD IN THE CENTER OF THE FIREWALL
