Trigger Remote Start w/existing alarm
leoslocks
Member - Posts: 6
Posted: January 07, 2006 at 11:30 AM / IP Logged
I have a 1999 Ford E 250 with a J-635 Alarm installed. I want to add a J-Start 3 remote start to the alarm.
I am not an alarm installer and did not install this alarm. Much of the instructions presume experience and knowldedge I may not aquire.
I do think I have connected the J-Start large wiring correctly. Where I am having trouble is getting the alarm to trigger the J-Start.
From the J-635 manual:
⇒ Gray Wire: Trunk release (Auxiliary channel 3) output. This wire supplies a 250 mA negative (-) output when the ‘TRUNK (3)’ button is pressed and held for 1.5 seconds. This output can be used to operate trunk release motors, remote starter units, etc. **Note** In most cases a relay must be used with this output. See diagram for relay hookup.
From the J-Start 3 manual:
Gray Wire: Auxillary negative output. Use this wire to control any extra relays needed to properly start the vehicle.
Orange Wire: Negative trigger input. Connect this wire to the output of the alarm or keyless entry unit that will be controlling the J-Str/3 unit. This wire is not needed when installing the J-Str/3-T unit. (the 3-T is an alarm and remote start in one unit..Not what I have.)
I have tried using the Gray wire (250mA negative putput) from the Alarm (J-635) connected to the Orange (Negative trigger input) wire of the Remote Start. Nothing happens.
Would using a Relay make this work? If so, how would it be wired?
J L Troy alarm, Home Page
J-635 pdf Here
J-Start 3T pdf Here
mo12v
Posted: January 07, 2006 at 4:49 PM / IP Logged
If you GROUND the Orange Wire on the Remote Start......Does it Start??
If so, (usually) you wouldn't need a Relay.
If Not, are you sure the ORANGE wire is the R/S wire?
SPDT Relay:
PIN 87 = ORANGE Wire on R / S
PIN 87a = XX
PIN 30 = GROUND
PIN 85 = GRAY Wire Output from J-635
PIN 86 = Constant 12 volt ( + )
MO
Mike M2
Platinum - Posts: 2,652
Posted: January 07, 2006 at 4:58 PM / IP Logged
A relay shouldn't be needed. Do you have a hood pin switch connected to the blue wire? Make sure this wire doesn't have a ground on it as it will do absolutely nothing if it does. Like Mo says, a simple ground pulse to the orange should do the trick.
Mike M2
Tech Manager
CS Dealer Services
leoslocks
Member - Posts: 6
Posted: January 07, 2006 at 11:02 PM / IP Logged
Sometimes it will start, other times it will start and die, ... start and die, three times then disable the alarm.
There is a motion sensor that has not been disabled. When I get the remote start to trigger from the #3 button of the remote transmitter, I will work that out.
There is no Hood Pin Switch attached to the blue wire.
I will try the relay and see if that works.
Thanks for the replys.
Mike M2
Posted: January 08, 2006 at 7:57 AM / IP Logged
If it's starting sometimes it's not going to be a problem with wiring. It's probably a tach wire issue. You could try flipping switch 1 to voltage and see if it works then.
Mike M2
Tech Manager
CS Dealer Services
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
