door lock diagram ram 2003
mtorres
Member - Posts: 6
Posted: January 10, 2006 at 7:13 AM / IP Logged
Hi, I'm trying to find a diagram for a 2003 dodge ram to make the door locks work. I know it takes relays and resistors and I have them already but I need a diagram. The alarm is an audiovox APS-785 w/ remote start. Also need to program second  remote. Any help would be great
mo12v
Posted: January 10, 2006 at 8:47 AM / IP Logged
2 SPDT RELAYS:
LOCK:
PIN 87 = Ground
PIN 30 = 820 ohm Resistor to Vehicles WHITE / D. Green wire
PIN 85 = Negative Lock Output from APS-785
PIN 86 = Constant 12 volt ( + )
UNLOCK:
PIN 87 = Ground
PIN 30 = 330 ohm Resistor to Vehicles WHITE / D. Green wire
PIN 85 = Negative UNLock Output from APS-785
 WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.
MO
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
