Posted: January 12, 2006 at 8:41 AM / IP Logged
Posted: January 12, 2006 at 10:58 AM / IP Logged
Posted: January 12, 2006 at 11:21 AM / IP Logged
Posted: January 12, 2006 at 2:38 PM / IP Logged
Posted: January 12, 2006 at 3:05 PM / IP Logged
Posted: January 12, 2006 at 5:50 PM / IP Logged
Posted: January 12, 2006 at 6:28 PM / IP Logged
Posted: January 12, 2006 at 6:43 PM / IP Logged
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
You may want to change the values of R1 and C1 for whatever delay time is needed, this may be longer than you need, in the range of about 5 seconds. Use a smaller C1 for a shorter delay time-
If the lock/unlock pulse is too long and the honk is more than a short toot, you can add more stuff to shorten it-
Add fuses as necessary, etc.
The keysense is a good idea if you have it; then you can delete all the delay relay nonsense.
