2006 Saturn Ion
Mr_Fusion
Copper - Posts: 113
Posted: January 13, 2006 at 11:52 PM / IP Logged
After studying many posts and wire diagrams, I cannot seem to locate a clutch bypass wire for a 2006 Saturn Ion Red Line, or any other year Saturn Ion. What is the reasoning behind this??
Chris Luongo
Platinum - Posts: 3,746
Posted: January 14, 2006 at 7:46 AM / IP Logged
Some professional shops won't do manual-transmission remote start at all, and even for those of us who do, we don't get a whole lot of people asking for them. So I guess it just doesn't get thought about too often.
Anyway, the underdash of an Ion is practically a wide-open cave under there.
Just look at the clutch pedal, find the switches, and test........ how hard can it be? They're only gonna have two wires each.... so that's only four wires to test.
One switch is to disengage the cruise control (if you have it); that switch will trip as soon as you push the clutch in just a little bit.
The other switch, to allow the car to start, it won't trip until the clutch is nearly to the floor......... one of the wires will always stay the same, and the other will change status as you push the clutch down.
Mr_Fusion
Copper - Posts: 113
Posted: January 14, 2006 at 2:04 PM / IP Logged
Every other diagram I pull for a car/truck that could have a manual transmission always has the type of clutch switch on the diagram but the Ion is the first one that I encountered that does not list anything for it.
Yes, I know what I am doing and I know how to determine the type of switch once I have the car, but I just like to be prepared and there has to be some reason why diagrams don't list the clutch switch.
dea,can
Copper - Posts: 284
Posted: January 14, 2006 at 4:00 PM / IP Logged
its the same as a 2005 ion clutch bypass its high up in the dash the wire is yellow its taped up very good with time you will find it  the starter wire from the remote start goes there.
dragon
dea,can
Copper - Posts: 284
Posted: January 14, 2006 at 4:04 PM / IP Logged
2005 ion help find wires go to autostart.ca then go to downloads then type this number then so on .533865167464 can only use it on this car.
dragon
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
