1990 toyota townace
desh187
Copper - Posts: 310
Posted: January 18, 2006 at 9:22 PM / IP Logged
Has anyone installed a keyless entry on this vehicle?I have already done the alarm but couldnt get keyless to work.This vehicle is a Japanese import, a right hand drive 4 wheel drive diesel .It has a door lock switch on the drivers door and i got blue/red(lock) and blue/black (unlock)wires at the door switch.It seemed like a 5 wire reversal rest at ground but wouldnt work even after i used a door lock module.It does not have central door locking or i would have used an actuator in the drivers door.
Any ideas would be much appreciated.Thanks.
Powermyster
Silver - Posts: 962
Posted: January 19, 2006 at 4:16 AM / IP Logged
cut the wires you think are lock and unlock and attach your lock and unlock wires the switch side.
Why oh Why didn't i take the blue pill
Darren Power
desh187
Copper - Posts: 310
Posted: January 20, 2006 at 12:01 AM / IP Logged
Sorry dont understand what that means,could you explain in detail?thanks.
redpeppers
Silver - Posts: 483
Posted: January 20, 2006 at 12:25 AM / IP Logged
so it does or does not have an acuator in the drivers door?
Where theres is a wire there's a way.
desh187
Copper - Posts: 310
Posted: January 20, 2006 at 12:29 AM / IP Logged
Yes it does have an actuator in drivers door but is not central locking system.
Powermyster
Silver - Posts: 962
Posted: January 20, 2006 at 3:08 AM / IP Logged
alot of japanese cars you have to add an actuator..
i have seen before on systems with neg locking. where you can't actually tap into the ocking wires you have to cut them and sent the neg's direct to the switch/actuator.
do you ot know wether the car has an actuator in teh drivers door
Darren Power
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
