2002 Ford Focus locks
midwestaudio
Member - Posts: 6
Posted: December 25, 2002 at 8:58 PM / IP Logged
Hi I'm new to the remote starter and security install world. Could anyone tell me what kind of locks are in the "02" Ford Focus? and a wiring diagram would be great also.
Thanks: Jason
10nesne1
Silver - Posts: 284
Posted: December 25, 2002 at 9:53 PM / IP Logged
Ford
Focus
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GRAY/BLACK
IGNITION SWITCH HARNESS *
Ignition  #1:
GREEN/ YELLOW
IGNITION SWTICH HARNESS
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
YELLOW
Brake  Light:
GREEN/ RED (+)
AT SWITCH ABOVE PEDAL **
Tach  Signal:
BLACK/ LT. GREEN
AT COIL MODULE
Parking Lights:
ORANGE / YELLOW (+)
AT LIGHT SWITCH
Headlights:
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With Ford's Passive Anti-Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems. ** This Wire Is Only Active When The Ignition Is On.
Ford
Focus
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
GRAY/BLACK
Ignition  +12 Volts:
GREEN/ YELLOW
Dome  Lights/Superv:
OEM Horn:
Power  Lock:
BLACK/ RED (-)
DRIVER'S KICK IN DOOR BOOT ***
Power  Unlock:
BLACK / YELLOW (-)
Trunk  Release:
BLACK / YELLOW (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
Notes:
*** See Installation Note # 201 - Negative Pulse Door Lock Diagram.
midwestaudio
Member - Posts: 6
Posted: December 27, 2002 at 3:42 PM / IP Logged
10nesne1:
Where can I find the installation note in your reply? #201 and #144
2002 Ford Focus locks -- posted image. and thanks for the diagram.
Thanks: Jason
