Neutral safety switch
kaezoo
Copper - Posts: 125
Posted: February 08, 2006 at 1:31 PM / IP Logged
Are there any vehicles that require locating the NSS for remote start, assuming the vehicle has an automatic transmission and the starter wire connection is made at the ignition harness?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 08, 2006 at 1:55 PM / IP Logged
Asking a broad question like that...youll get a broad answer. Its not the vehicle that requires locating a neutral safty switch or wire its the R/S unit....Some do, some do not....Most do not. Its a way of making sure the vehicle will not start if left in any gear.
kaezoo
Copper - Posts: 125
Posted: February 08, 2006 at 2:04 PM / IP Logged
Let me rephrase the question. All the remote starts I install include a NSS interface wire. All the vehicles I install in are automatics. In almost every vehicle, I just ground the wire through a toggle switch. Assuming that I always make my starter wire connection at the ignition harness, does anyone know of a vehicle that might start in gear if I ground the wire instead of connecting to the NSS?
JWorm
Platinum - Posts: 2,208
Posted: February 08, 2006 at 2:48 PM / IP Logged
You install DEI stuff? They list some vehicles that you are supposed to hook it up on. Old Dodge trucks I believe....and a couple others. Check the manual.
kaezoo
Copper - Posts: 125
Posted: February 08, 2006 at 3:37 PM / IP Logged
Yep, they list certain Chrysler and GM models with mechanical neutral safety switches. However, the diagrams you'll find in the manuals don't actually use the NSS wire. Does anyone ever do anything but ground this wire on automatics?
JWorm
Posted: February 08, 2006 at 3:48 PM / IP Logged
I connect it to the on/off switch that comes in the box. Other side of switch goes to ground. Gives the customer a way to shut down the remote start. Although 99% of customers probably never use the switch, unless they hit it accidently.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
