2005 Tacoma remote start problems
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 9:06 AM / IP Logged
AFter messing with this for hours yesterday I found the problem..I have a Crimestopper 2016....no factory alarm...if the lock/unlock circuits are disconnected from alarm and I lock manually truck remote starts all the time with no problem
When I lock/unlock it will not remote start and sometimes doesn't even lock/unlock.....anyone know what the damn problem is??  This truck is a PITA to hook anything up to....tried using purple and blue/white to lock  and both GREEN/ black and gray to unlock....neither works
Please help!!!
mo12v
Posted: February 12, 2006 at 10:19 AM / IP Logged
Are you using the Keysense wire?
Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
MO
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 10:21 AM / IP Logged
I don't have a factory alarm
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 10:22 AM / IP Logged
Now that the damn unlock/lock circuit thing isn't hooked up its not remote starting again...i here the relay click no ignition or anything then it just locks and arms.
Platinum - Posts: 12,488
Posted: February 12, 2006 at 11:13 AM / IP Logged
Did you hook up the starter disable circuit & also what bypass module did you use for the Immobilizer ? In your last post you said that you disconnected the locking circuit & it still locked ? How is this possible if you disconnected this feature from the truck ?
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 2:49 PM / IP Logged
OK...I did figure out what is going on but don't know why....
Once the truck arms and sits for about a minute it will not remote start...I don't even hear the relay inside the remote start click at all...it's like it doesnt even attempt to do anything..it just locks and thats it
I did not even hook up the starter disable circuit at all because my truck has that stupid chip in the key and wont start unless the specific keys are used..  I used the 556U for the byapss module...
Locking and unlocking works...I did hook that back up...
Really sounds to me like something is screwed up with the RS...anyone have any suggestions?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 12, 2006 at 3:26 PM / IP Logged
Like Mo said...if you power up the key sence GREEN/ blackNEG(-) at the ign. switch. The truck WILL start. Use the status wire to trigger it!
Crimestopper might call it ground while running
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 3:38 PM / IP Logged
tried that too and it doesnt do anything....
My remote start doesnt turn on the ignition...nothing at all...it just locks the doors...the ignition relay doesnt click at all....I even put a key in the igntion and left it off....tried remote starting and it still didnt even try at all...
nokia15291
Copper - Posts: 59
Posted: February 12, 2006 at 4:57 PM / IP Logged
OK...check this out...just went back out to finish shoveling snow....and it remote started fine!!!  but i did notice that the alarm wasnt on...turned it off and and tried remote starting again...then i actually armed the system and tried remote starting...this is when I get no response.  So it appears something is messed up with the 2016 unit in my opinion...anyone else have an idea?
ky1960
Member - Posts: 17
Posted: February 12, 2006 at 6:18 PM / IP Logged
recheck all the connection to ensure the power work properly and ground
kvn
Page of 4
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
