02 Trailblazer start then stop
xtac1080
Copper - Posts: 89
Posted: February 12, 2006 at 5:02 PM / IP Logged
I'm doing my first 02' Trailblazer RS and I can get the thing to remote start, but after about 5 seconds the vehicle shuts down. Anyone have any ideas why it would do this? I'm using a Valet 561R RS & a Directed 555LW bypass. I'm pretty sure i've done something wrong with the ACC & IGN wires, but I cant figure it out. Any feedback is much appreciated!
mo12v
Posted: February 12, 2006 at 5:04 PM / IP Logged
Did you program for TACH?
Is your Theft light flashing
MO
xtac1080
Copper - Posts: 89
Posted: February 13, 2006 at 1:13 AM / IP Logged
Theft light is not flashing. I found and confirmed the white tach wire under the hood and it is hooked up. This truck sucks!
redpeppers
Silver - Posts: 483
Posted: February 13, 2006 at 1:57 AM / IP Logged
r u sure u have the bypass module wired up right.....we need more info to help u......wire colors and were u taged them.....also like mo12v said ...did u learn the tach rate, (tagging the tach wire and programming tach to the remote start are two different things)?  that is very important.....
Where theres is a wire there's a way.
chriswallace187
Gold - Posts: 1,661
Posted: February 13, 2006 at 2:15 AM / IP Logged
1. Did you learn the tach?
2. Are your passlock wires hooked up correctly?
3. Are you powering the pink and the white ignitions, and the orange and the brown accessories, as such? (The BCM uses the accessories to know when to look for the Passlock code, so they can't be powered as ignition).
C Renner's Auto Electronix
customak47
Copper - Posts: 164
Posted: February 14, 2006 at 3:21 PM / IP Logged
what's happening is the unit is cranking and not seeing the truck running, but because this vehicle has overcrank protection factory, the truck stops cranking itself and runs, but the remote start is still juicing the crank wire. then when max crank time is met, it shuts down having seen a fail to start. so your problem is the unit is in tachless mode even though you have the tach wire hooked up. these trucks are not that hard so take a break and a step back.
My rifle is my friend...
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
