02 Toyota Sequoia remote start
Ren92
Copper - Posts: 56
Posted: February 15, 2006 at 6:33 PM / IP Logged
I have a 02' Sequoia that I am putting a remotestart on and have everything working but the locks. I know it should have a RED / yellow and a l.GREEN/ red and a l.GREEN/ black in the kick panel but it doesn't. I took the door panel off and found them but the l.green wires don't lock or unlock the truck. Does anyone know what the deal is with this truck? I just did a 01' last week and had no problem with it.
JWorm
Platinum - Posts: 2,208
Posted: February 15, 2006 at 7:01 PM / IP Logged
Did you do the funky relay setup?
You are never going to find them in the kick panel on a Sequoia. You always have to go in the door.
Hornshockey
Silver - Posts: 520
Posted: February 15, 2006 at 7:19 PM / IP Logged
JWorm's right, you've got the right colors, but they're in the door at the door ecu, not in the kick panel. You can use this setup to make them work
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1070.pdf
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Ren92
Copper - Posts: 56
Posted: February 16, 2006 at 1:20 PM / IP Logged
thanks guys that worked.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
