Ford ECM Tx and RX
fyerfytr
Member - Posts: 10
Posted: February 16, 2006 at 4:24 PM / IP Logged
Installing bypass module PKF-1
Is the ECM located on the pass. side kick panel? Anyone know off the top of their head which is Tx and RX? Just about done -
kgerry
Platinum - Posts: 3,455
Posted: February 16, 2006 at 4:28 PM / IP Logged
follow the 4 pin plug off the ign cylinder...it'll go to a plug to the right of the column... thats usually where i grab these wires.....
any more info would require you mentioning what type of Ford vehicle you are working on.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
fyerfytr
Member - Posts: 10
Posted: February 16, 2006 at 5:25 PM / IP Logged
thanks, it's a 00 expdeition.
Also on the door triggers I used the light blue/white from the factory remote entry and hooked the - door trigger wire to it and it kept saying the door was open when it was close and i would open while armed and it did not sound.
It is the compustar remote start/alarm combo  2wssas
thanks again!
Mark
Platinum - Posts: 12,488
Posted: February 16, 2006 at 6:05 PM / IP Logged
For the RX & TX wires, if your not sure connect them up and remote start the vehicle. If it fires up you got the right ones, if it sits there and does nothing or cranks and doesn't start, reverse the wires and reprogram the module and it will work.
As far as the door triggers go, did you use the RED or the RED / WHITE wire from the Compustar unit's harness ? Sounds like you used the (+) door trigger input instead of the negative ( RED / WHITE )
fyerfytr
Member - Posts: 10
Posted: February 16, 2006 at 7:02 PM / IP Logged
Jeff,
   Thanks for the reply, I will give that a try. I miss Canada! I am from Ont.
take care-
         Mark
fyerfytr
Member - Posts: 10
Posted: February 16, 2006 at 7:38 PM / IP Logged
I put the RED / white wire with the light blue/white and it does nothing.
I see a run of wires that look like they come from the ignition area, any idea which 2 of the 4?
extreme1
Silver - Posts: 1,070
Posted: February 17, 2006 at 12:45 PM / IP Logged
there are two blue/white wires at the keyless module, make sure you have the right one.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
fyerfytr
Member - Posts: 10
Posted: February 17, 2006 at 2:16 PM / IP Logged
I finally got the it bypassed. The problem I have now after remote starting the blower motor does not work. I have the white acc. wire from the remote starter hooked to the largeer grey and yellow wire per the manual, am I missing something?
Thanks ,
         Mark
2000 Ford Expedition 5.4l
2001 Honda Accord 3.0l
dea,can
Copper - Posts: 284
Posted: February 20, 2006 at 9:35 PM / IP Logged
Ign - 1 blue/lt green
Ign - 2 gray / YELLOW (2nd acc)
acc -1 RED / black
acc -2 BLACK/ green.
dragon
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
