00 Tundra Dome light
abad355ta
Member - Posts: 36
Posted: February 17, 2006 at 2:41 PM / IP Logged
Cannot find wires for the dome light on my Tundra. Looked on the database and it did not offer the dome light supervision diagram. I have a viper remote start with no factory alarm
thanks
ToDDR
mo12v
Posted: February 17, 2006 at 6:32 PM / IP Logged
If your Unit does NOT have built in Relay for D L S, then You need a Relay to supply GROUND to Door Trigger
Dome Light
BLACK/ WHITE
or   WHITE/ blue (-)
9 PIN CONN DRIVER SIDE JUNCTION BLOCK
or  drivers door harness
MO
Chris Luongo
Platinum - Posts: 3,746
Posted: February 17, 2006 at 7:07 PM / IP Logged
When you unlock the doors, the domelight comes on anyway, as long as the engine isn't running.
