Audiovox aa-925 problem
jcs400ex
Posted: February 18, 2006 at 12:10 PM / IP Logged
I just installed an Audiovox aa-925 Keyless entry system in my car.  Everything works fine, except the door locks.  The door will lock, but it will not unlock.  I can hear the box clicking, and I can hear the door locks trying to pop, but they won't actually unlock.  The doors lock just fine.  Whats the deal?
kohara73
Copper - Posts: 192
Posted: February 18, 2006 at 12:18 PM / IP Logged
What kind of car???????
Keith
jcs400ex
Posted: February 18, 2006 at 12:28 PM / IP Logged
2001 Chrysler Sebring, with single wires system.  I installed the resisotrs already.  After a little more playing around, I realized that if hit lock on the FOB, it locks the doors, and if i hit unlock on the key fob, it also locks the doors.  I think I need to reverse the polarity of one of the wires with a relay, but I can't remember how.
JWorm
Platinum - Posts: 2,208
Posted: February 18, 2006 at 2:02 PM / IP Logged
Your resistor wire on the unlock wire is wrong. Your polarity is fine.
mo12v
Posted: February 18, 2006 at 2:05 PM / IP Logged
Check your Resistance:
If it is a 2001 Sebring Sedan:
Door Locks Require +12v Pulse Thru 1800 Ohm Resistor For Lock And +12V Pulse Thru 750 Ohm Resistor For Unlock.
MO
jcs400ex
Posted: February 18, 2006 at 2:44 PM / IP Logged
I'm starting to get mad now, lol.  I finally made sure I had  +12v to the unlock, and did get the doors to unlock.  Now, the door won't lock.  If I hook up only unlock, it wil unlock, and if i hook up only lock, it will lock.  But if I hook up both, it only locks.
mo12v
Posted: February 18, 2006 at 2:49 PM / IP Logged
Are you using Relays?
Or, does your Unit have + / - Outputs ??
MO
jcs400ex
Posted: February 18, 2006 at 3:12 PM / IP Logged
I will post the exact information from the wiring diagram with the unit.
(-) Lock Pulse( +)Unlock Pulse - Red wire
(-) Unlock Pulse (-) Lock Pulse - Green Wire
RED / Black (-) 2nd unlock only
I tried w/ relays and without, switching the wires on the resistors, somehow the door will even lock without a resistor hooked up.
mo12v
Posted: February 18, 2006 at 3:24 PM / IP Logged
Have you tried Direct 12 Volts to each Resistor to Only LOCK & then UNLOCK to be sure you have the correct resistance?
MO
