2006 Toyota Sienna Alarm/Remote Start Wiring
stephen0715
Member - Posts: 15
Posted: February 26, 2006 at 12:01 AM / IP Logged
Need wiring diagram of 2006 toyota sienna for installing alram. Anyone can help? Thanks!
Mike M2
Platinum - Posts: 2,652
Posted: February 26, 2006 at 8:33 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / SIENNA / 2006 / Remote Start
[PRINT THIS PAGE]
12volts wht/red (30A), wht/blue (7.5A) +  ignition harness
Starter BLACK / YELLOW  +  ignition harness
Second Starter N/A
Ignition black  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory pink  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock lt. green  -  driver kick, 18 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue (double pulse)  -  driver kick, 18 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue / YELLOW (-) in the passenger kick in a 12 pin plug.
Lock Motor blue/red  5wi driver kick, 12 pin plug
Unlock Motor WHITE/ red to red  5wi driver kick, 18 pin plug
Parking Lights+ do not use, relay rests at gnd
Parking Lights- GREEN/ black  -  headlight switch
Hazards BLACK/ orange  -  hazard switch
Turn Signal(L) GREEN/ black  +  R side of fuse box, 30 pin plug
Turn Signal(R) GREEN/ YELLOW  +  R side of fuse box, 30 pin plug
Reverse Light RED / black  +  driver kick, harness to rear
Door Trigger blue  -  interior light switch on dash
Notes: Can also use individual door trigger wires. The driver door is RED / yellow in the 16 pin plug, pin 14 at the BECU. The passenger door is RED / yellow in the 28 pin plug, pin 23 at the BECU. The left sliding door is gray, pin 19, in a 25 pin plug on the right side of the fuse box. The right sliding door is RED / white in the 16 pin plug, pin 16 at the BECU. The hatch door is GREEN / WHITE in the 28 pin plug, pin 25 at the BECU. Use all wires and diode isolate each.
The BECU (Body ECU) is attached to the back of the fuse box under the driver side dash.
Dome Supervision RED / green  -  interior light switch on dash
Trunk/Hatch Pin common with door trigger wire
Hood Pin RED / white  -  BECU, 10 pin plug, pin 10
Notes: The BECU (Body ECU) is attached to the back of the fuse box under the driver side dash.
Trunk/Hatch Release yellow/red (power back door)  -  bottom L of fuse box, 22 pin plug
Notes: On vehicles without the power back door, the hatch release is GREEN/ black (-) at the BECU, 28 pin plug, pin 3. Meter this wire while open the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/black (+) at the BECU, 26 pin plug, pin 1.
Power Sliding Door YELLOW /GREEN (L), purple (R)  -  bottom L of fuse box, 22 pin plug
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange  ac  ECM, top plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / white  -  R side of fuse box, 36 pin plug
Horn Trigger GREEN/ black  -  horn switch
Memory Seat 1 pink/blue  -  seat memory switch in door
Memory Seat 2 lt. GREEN/ black  -  seat memory switch in door
Memory Seat 3 N/A  -
2006 Toyota Sienna Alarm/Remote Start Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on LE, XLE and Limited models.
Mike M2
Tech Manager
CS Dealer Services
stephen0715
Member - Posts: 15
Posted: February 27, 2006 at 5:47 PM / IP Logged
Thanks a lot ! Mike M2
automan25
Posted: February 27, 2006 at 9:06 PM / IP Logged
need wiring diagram of 2004 mercedes benz for installing alarm.anyone can help ?thanks!
chan
