Is the Rearm wire mandatory?
equate
Copper - Posts: 118
Posted: March 13, 2006 at 11:41 AM / IP Logged
I found some remtoe starter doesn't have rearm output. Is there any problem for some vehicles?
Twelvoltz
Platinum - Posts: 2,384
Posted: March 13, 2006 at 11:44 AM / IP Logged
The vehicle does not care, but the owner might. There are a lot of vehicles in which you cannot arm the factory security system via a wire. This connection is only used when the vehicle can be armed via a wire.
JWorm
Platinum - Posts: 2,208
Posted: March 13, 2006 at 12:09 PM / IP Logged
It is also used on a lot of vehicles to pulse a doorpin wire to shut off retained accessory power or automatic headlights.
Required? No. But when you get calls from customers compaining about there battery being dead you will wish you had hooked it up.
Twelvoltz
Posted: March 13, 2006 at 3:16 PM / IP Logged
That too!
Missed that one, thanks JWorm!
equate
Copper - Posts: 118
Posted: March 14, 2006 at 12:04 PM / IP Logged
which vehicles and if this alarm has auto-rearm, will it work for that?
thepencil
Gold - Posts: 1,526
Posted: March 14, 2006 at 1:35 PM / IP Logged
GM product!
Be careful whose advice you buy, but be patient with those who supply it.Is the Rearm wire mandatory? -- posted image.
equate
Copper - Posts: 118
Posted: March 15, 2006 at 2:58 AM / IP Logged
thepencil wrote:
GM product!
thanks. Which model and year?
thepencil
Gold - Posts: 1,526
Posted: March 16, 2006 at 10:14 AM / IP Logged
Buick Regal 2002, negative pulse to shut off radio.
GMC Jimmy 2002...etc.
JWorm
Posted: March 16, 2006 at 11:26 AM / IP Logged
equate wrote:
thepencil wrote:
GM product!
Do you really want someone to list every vehicle it is neccessary to hook a rearm wire up on??? Here's what I do. When you shut the car off with the key does the radio shut off? If it stays on until a door is opened I hook the rearm wire to a true door trigger. If the headlights stay on until a door is opened I also hook up the rearm. On some of these vehicles those circuits may shut off after 5 minutes, maybe even 15. But on some vehicles those certains will stay on until the battery dies or a door opens. Nissans with auto headlights, and recent Toyotas with auto headlights are just a few. I've heard a 2005 GM van will keep the radio on until a door is opened or the battery dies. Previous years they would shut off after a few minutes.
equate
Copper - Posts: 118
Posted: March 18, 2006 at 3:27 PM / IP Logged
thanks a lot for above friends.
