Immobilizer light flash after RemoteStart
oo7123
Posted: March 14, 2006 at 8:19 PM / IP Logged
Just a quick question. I installed the DEI 555D bypass yesterday on a 1997 prelude,
everything works fine, but the immobilizer light on the dash will continue
to flash after remote started. Is it normal after added bypass module? it just seems very annoying during driving. or the light should be off after remote start. Let me know. Any info would help. Thanks.
xscash
Copper - Posts: 317
Posted: March 14, 2006 at 8:31 PM / IP Logged
there is a prob.  light should be out...ive had the same prob with a dei peice, but it was a cadilac. i ended up using a key.
XS
oo7123
Posted: March 15, 2006 at 1:01 AM / IP Logged
So, is it a DEI design problem ? or a defective DEI 555D unit I have?
kobevsjordan
Member - Posts: 13
Posted: March 15, 2006 at 3:45 AM / IP Logged
Do you have the blue wire connected to the Remote Start (status) output or your alarm?
I had the same problem on my car and realized that i hadn't connected this wire to the correct wire.
Hope this helps
A
oo7123
Posted: March 22, 2006 at 4:14 AM / IP Logged
Yes, I did connect the blue wire to the remote start status outout. But it still doesn't turn off the immobilizer light on the dash.
so sad.
Twelvoltz
Platinum - Posts: 2,384
Posted: March 22, 2006 at 5:26 PM / IP Logged
Although possible it is unlikely that the DEI piece is bad. When you did the installation, did the unit confirm that it programmed?
nipplz
Member - Posts: 24
Posted: March 22, 2006 at 7:06 PM / IP Logged
be careful when reading the instructions because of all the important bits and peices of info that dei gives you.  is there any way that you may have overlooked somthing?  i have not had to use one of these modules so the info in my library is limited, sorry
