window module activation input
xtremespeed
Member - Posts: 38
Posted: March 19, 2006 at 8:04 PM / IP Logged
I am hooking up a window module to my prestige keyless entry. I want the windows to roll up when I lock the car with the keyless, but the module won't continue to run with a ground pulse activation input. It requires the ground remain on until the windows are all the way up. Am I going to have to add relays to provide a constant ground when the doors are locked?
mo12v
Posted: March 19, 2006 at 8:41 PM / IP Logged
Does you Keyless have Starter Kill??
MO
xtremespeed
Member - Posts: 38
Posted: March 19, 2006 at 8:42 PM / IP Logged
No.
mo12v
Posted: March 19, 2006 at 8:48 PM / IP Logged
May have to use a Timer ...........  If you configure a Latched Relay, you would have to come up with a way to disconnect after the Windows are up........
MO
doibuy
Copper - Posts: 177
Posted: March 19, 2006 at 9:30 PM / IP Logged
Is there an orange wire coming off the brain?  This is the ground when armed wire, this will trigger the window module to roll up each time you arm it.
xtremespeed
Member - Posts: 38
Posted: March 19, 2006 at 9:49 PM / IP Logged
There is not an orange ground when armed output. I don't have an alarm,  just a keyless with remote start. I guess that's why it doesn't have this wire. I hooked the window module to the lock wire, and it works, except, as soon as the doors lock, the module stops running. The windows only go up about 4 inches. I have 3 of these modules, and they are all the same. These are the first ones I have seen like this. The ones I used before just required a single pulse to activate the module, and then it would continue rolling the windows up all the way.
xtremespeed
Member - Posts: 38
Posted: March 19, 2006 at 11:12 PM / IP Logged
i went ahead an ordered a dei pulse timer. Thanks for the help.
