Adding a pin switch to a Viper 350HV
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 1:17 PM / IP Logged
I have a 98 S-10 2.2L 5-spd. I want to add a pin switch or something to that effect. I want it to set off the alarm when the tailgate opens. Is it possible and how would I do it?
Would I just T-tap into the door pin switch? Its a neg signal.Would I just use one wire for the pin switch?
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 2:31 PM / IP Logged
Whats a magnetic reed switch?
Why no t-taps?
I have a 1 wire pin switch.
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 2:56 PM / IP Logged
Ahhh I see.
Why not use just the pin switch and have my taligate push against it. (like dome lights and the pin switch in the doors).
Why use the reed switch?
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 3:02 PM / IP Logged
So the reed switch is a type of back up?
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 3:03 PM / IP Logged
so should I use a positive in the switch since it is already grounded? Will I need a relay since my door trigger is negitive?
importhunter
Copper - Posts: 76
Posted: March 21, 2006 at 4:28 PM / IP Logged
So what about just using the pin switch?
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
