windows up from motion sensor
78musicman
Copper - Posts: 78
Posted: April 06, 2006 at 4:14 PM / IP Logged
I am trying to figure out how to wire this.I have aux to control the windows but if i vent it how can i control it off of the warn-away neg trigger so that once it sends a trigger pulse once that it stays latched untill reset with the ground armed wire .I am learning and additted to this site.Thanks 12 volt
colorado tap the rockies
xscash
Copper - Posts: 317
Posted: April 06, 2006 at 5:56 PM / IP Logged
does your window rollup unit have a bypass if the wire remains on? if so here is a diagram to turn a momentary to a constant.
windows up from motion sensor -- posted image. Momentary to Constant Output
Once activated by the relay on the left, the relay's coil on the right will stay energized until either ground or 12v(+) is removed. You can do this with another relay. Or try connecting to a 12v(+) switched source instead of a constant one. Or you can have a door trigger activate a relay to break continuity. The variations are practically endless.
expandable sound
south of boston
78musicman
Copper - Posts: 78
Posted: April 06, 2006 at 6:25 PM / IP Logged
How can i set it up for the motion sensor to send one pulse then it can not keep sendind a pulse untill it is disarmed and armed using the ground when armed wire as help.Because my aux wire sends a 1 second ground to trigger up.If not i will have to use lots of relays to change the aux wire to constent as well.The window module can be set up as either momentary pusle or constant or latched.Thanks
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
