Powerlocks and keyless arent working
skeet44
Posted: April 24, 2006 at 9:33 AM / IP Logged
Installed a clarion dxz945mp last night and got everything working fine and hooked up the constant to the ignition and power wire on the deck, but didn't work without the keys. So I hooked up the deck as regular and after everything was in and working i found out my power locks wouldnt work without my keys in the ignition and my keyless entry wouldnt work. I have a '98 mustang. Anybody have any ideas?
Moderator - Posts: 12,488
Posted: April 24, 2006 at 11:14 AM / IP Logged
Remove the wiring that you have added or spliced into and see if your problem persists. Sounds like you may have cut into a wire that you shouldn't have. Also did you have the Mach system or just the normal Premium Sound ?
