94 Honda Prelude alarm problem
empoy55
Posted: April 24, 2006 at 8:30 PM / IP Logged
can please any body help me!!!...my question is do i really need to put a relay on my alarm to make my keyless door lock works?..and can some body help me find the wires for the Negative Door Triggers and Positive Door Triggers cause i want my alarm to go off when the my door opens..my car is a Honda Prelude 94..THANKS I HOPE SOMEBODY CAN HELP ME WITH MY PROBLEMS...
jp
Twelvoltz
Platinum - Posts: 2,384
Posted: April 25, 2006 at 7:29 AM / IP Logged
First, what make/model is the system you are trying to install?
If you take a look at this page it will give you the wiring information for your vehicle. It shows that to activate your power door locks you need to provide a negative trigger to the vehicle's BLACK/ white to lock the vehicle and a negative trigger to the vehicle's BLACK/ red to unlock the vehicle. Depending on the make/model of your system you should not need extra relays to lock and unlock via the new system.
Your car uses negative door triggers, so you would not need to use the wire listed for positive door trigger input.
Hope this helps.
Keep us posted.
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
