2002 chevy blazer remote start
duallyit
Member - Posts: 17
Posted: April 30, 2006 at 2:39 PM / IP Logged
I have a remote start  asian wolf 2009 version 2, bypass box 555l which by passes the factory alarm . The alarm says that you can hook up both wires, door trigger and dome light supervision .This I can't figure out cause the door trigger switches has to be diode driver side tan ,passenger door orange,rear doors and hatch is dark blue to the bcm.If all these have to be diode how do you connect them to a dome light supervision ?and can you stil ?
The factory  alarm has it were you can double click the remote the back glass then will pop the glass window while the alarm is still activated ,this then allows the light to also come on and stay on when i close the back glass the light goes off .
If I connect the door trigger switch to the dome light supervision from the alarm how does the trunk release know not to set off the alarm ? When the button is hit to relase the trunk? Because this will then turn on the dome light supervision and the alarm will then sound off.
Please help me if any one has the proper diagram way of connecting this alarm up to simplify my situation with the bypass hooked up . I am about to burn up my brain !!!!
duallyit
Twelvoltz
Platinum - Posts: 2,384
Posted: April 30, 2006 at 3:34 PM / IP Logged
1. Here is a nice how-to diode isolate guide that shows not only how the diode is supposed to face, but also where to cut it in. As far as the dome supervision, your system probably only provides a - 500ma output, and is not typically enough current to turn the dome light on, you will more than likely need a relay for dome supervision.
2. The BCM has a wire that will pop your rear hatch, make sure to set the alarm to disarm anytime you use the aux chanel output.
3. The 555L does not bypass the factory alarm, it bypasses the factory antitheft system, allowing the vehicle to start, these are two seperate items. The factory alarm can be disarmed by providing a ground pulse to a specific wire.
Hope this helps
2002 Blazer wire colors/locations.
