2001 eclipse, remote start
joe61177
Member - Posts: 34
Posted: April 29, 2006 at 6:02 PM / IP Logged
 ok in trying to add a remote start to an existing alarm im trying to find the wire diagram for the existing alarm  the problem im having is that i cant find a wire diagram for the alarm the model number is pro9549ft3 if anyone has the wire diagram it would be a big help thanks in advance
xscash
Copper - Posts: 317
Posted: April 29, 2006 at 8:21 PM / IP Logged
here is a link to the manual
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productid=3932&langId=-1
 its the blue trunk wire
   xs
expandable sound
south of boston
joe61177
Member - Posts: 34
Posted: April 29, 2006 at 10:11 PM / IP Logged
thanks ,one more ? do I only need to hook up one wire from the valet561 to the audiovox alarm to bypass it during autostart?
joe61177
Member - Posts: 34
Posted: April 30, 2006 at 10:38 AM / IP Logged
ok im gonna attempt in puting in a 561r remote start into a 2001 eclipse with the existing alarm the only thing is rhat im not sure what wires to connect from the 561r to the pro9549 to bypass it during remote starting
xscash
Copper - Posts: 317
Posted: April 30, 2006 at 3:09 PM / IP Logged
you could just use the acc wire for the alarm ign input and not power it during remote start. also you may need to bypass the shock sensor during start.
expandable sound
south of boston
joe61177
Member - Posts: 34
Posted: April 30, 2006 at 7:31 PM / IP Logged
ive just added a remote start valet561R to a audiovox pro9549ft3 the problem im having is mating them together not sure which wire from the autostart goes to the alarm .
mo12v
Posted: April 30, 2006 at 8:29 PM / IP Logged
If your asking what wire on the Valet Activates the Remote Start.....
WHITE / Blue needs 2 Ground Pulses to Activate R/S
So you would need a Ground Pulse from the Audiovox.......
Like Door Lock Pulse, or if it has a Negative Output for a R/S
MO
joe61177
Member - Posts: 34
Posted: April 30, 2006 at 8:34 PM / IP Logged
ive actually got that already the problem im having is bypassing the starter kill on the existing alarm so that the remote start works when the alarm is armed it will work when the alarm is off but not when its armed
cntrylvr79
Silver - Posts: 582
Posted: April 30, 2006 at 11:23 PM / IP Logged
You must hook the starter output of the r/s to the motor side of the cut starter wire.
Cause I'm So white and nerdy...
First Class Certi-fried installer
joe61177
Member - Posts: 34
Posted: May 01, 2006 at 7:26 AM / IP Logged
are you saying I should hook up the heavy gauge violet wire from the 561r r/s which is the starter output and connect it to the wire that goes to the starter (engine side) . I believe that wire was cut and goes to a relay . do I just tie it in there
